cyron1
Multiple instance installation failing
Hi all
I have set up an installer with a base instance and 1 multiple instance.
All works fine when I initially install the base instance and instance #1
I then increase the version number and try to install again where I am met with the dialog giving me a choice to install a new instance or maintain an already installed instance.
When I choose the install new instance option, it also works fine. The base instance is installed and the version number has increased
When I choose the "Maintain or upgrade an already installed instance" to upgrade instance #1 I get a dialog which says "The specified account already exists". and the installation fails.
Can anybody explain why this message comes up and how to get instance #1 upgraded?
Thank you for any replies
Cyron
Re: Multiple instance installation failing
Hello Cyron and welcome to Advanced Installer forums,
In order to have a clear view over your scenario, can you please send us the .AIPs (project files of your old and new version) and a verbose log of the "Maintain or upgrade an already installed instance" installation to support at advancedinstaller dot com so we can investigate them?
cyron1
Hi Daniel
Thanks for the reply
I have sent the file to your support inbox as requested
Cyron
Hello Cyron,
You are receiving the related error (Error 1316) because you have used different names for your MSIs (old and new version). Unfortunately, when you try to install a new version of a product instance (other than the default one) the upgrade installation will act like a patch. Therefore, when building a new version of your multiple instances project you should make sure all patches rules are fulfilled. This is because our multiple instances support is not compatible with the major upgrade scenario. You can take a look on our "Multiple Instance upgrade not working properly" thread which debates a similar topic.
So, can you please use the same MSI names in both of your project versions and see if this helped?
