cyron1
Running multiple instance installer from a command line
Hi all
I have created an installer with support for multiple instances.
Our aim is to install multiple instances of our web site on the one machine, but have each instance point to a different environment.
Over time, as the web site changes, we can use the installation package to update each site.
I am trying to effect this through a silent installation, so I'm tring to find out how to run the installation executable through a command line and pass in the instance id that I want to update. I have found some sites/your forum which details different ways, but I have not been able to make it work. I have tried
MySetup.exe /exenoui /newinst #0 PARAM1="a" PARAM2="b" /quiet /l*v "logfile"
MySetup.exe /exenoui /instanceid=0 PARAM1="a" PARAM2="b" /quiet /l*v "logfile".
I have tried moving the /newinst to the end, tried different combinations of 0 or #0 as the instanceid but all to no avail.
Is there a way for this to be done? Effectively by passing in the instance id, the installation can skip the multiple instance selection dialog and continue on to install the desired instance.
Thank you for any help on this
Cyron
Re: Running multiple instance installer from a command line
Hello Cyron,
If you want to upgrade or maintain an existing installed instance, then you should use the /upgrdinst, respectively /selinst commands.
Let us know if this helped.
