Newman
Service Dependencies modify
When i make a Build of a Software that install a Service with Dependencies: wmiApSrv[~]Winmgmt and a User has Change that Service Start Type to "Disable" the installer says by the Installation that the Server could not start and the Installation will abort.
That's OK, but I can not Show the User that these services must be started before installing.
Is it possible during the installation of the software to convert these services to Automatic befor (wmiApSrv[~]Winmgmt) the service is installed by the software?
Re: Service Dependencies modify
In order to achieve this, you can follow the first 4 steps described in the Sequence service stop/start and file removal thread.
Let us know if you have any other question.
Newman
The link is good, but it does not fit with version 11. I think the menus are not at all given there. Is it possible to get a screenshot?
- go in the "Custom Action" page and add a "Launch file" custom action after the "Install Execution Stage -> Paths Resolution" action group
- right-click in the "File to launch" field, select "File..." and choose your BAT file from the dialog that appears
- go to their properties dialog and in the "Registration" tab select the "Auto register file" option, then the "Extract registration info from native library" option with synchronization set to "Enabled"
You should implement only the following steps from what is described in the mentioned thread:
- create a BAT file that stops the services you need. For instance:
  • sc stop A
    sc stop B
- go in the "Files and Folders" page and add that file as a temporary file using the "Temporary Files" toolbar button
The UI did not change since version 11.0 and it looks like in the attached image.
Launch File CA.png (80.09 KiB) Viewed 2698 times
