t.tian
Template damage?
after I install the last update I got some trouble with my template. Any body has the same trouble?
Bye
Thomas
Re: Template damage?
Hi Thomas and welcome to Advanced Installer forums,
This happens because any other than Classic theme requires the Enhanced User Interface feature to be enabled. This feature is handled by our EXE Bootstrapper, but not by the MSI package. The "Enhanced User Interface" option can be found in the Themes page, Settingstab.
So, when you choose a theme, from the Themes page, that requires Enhanced UI, the package type is automatically turned to an EXE type in the Media page. Then, when the project is built it creates an EXE setup file and the MSI file next to it (the MSI file can also be included in the EXE file).
When you run your package, you should run the EXE file for the Bootstrapper to handle correctly all the dialogs and controls.
