afreesoul
some UI bugs in surface theme
I like surface theme, but I meet some bugs about UI.
1. I modify InstallDlg's Minimize attributes from False to True.
In Window Xp I can't minimize dialog by clicking icon in task bar.If I click it then move dialog, it will like p1 above.
In Winodw 7 I can minimize dialog by clicking icon in task bar.But If I click icon in task bar and move dialog, It will also like p1.
2.I use two combo box controls in p2 above.
You can see the text at left control which I set "Combo List" attributes to true is not in Vertical center.
If I set "Combo List" attributes to false is right in Vertical center.(See right control)
When I using left control by mouse wheel, the text will be in Vertical center.
3.I modify progress bar's Subscribed Events from "Display installation progress" to "Display overall installation progress".
If I add a large of files to package, progress bar will hold still.
I am sure that I have used Enhanced User Interface.
Re: some UI bugs in surface theme
This seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
I've tested your scenario but I cannot replicate the described behaviour. Can you please attach a sample .AIP (project file) which replicates this?
