jonathan.reyes1
Professional License - Fixing Truncated and Wrapped Text
Hi I have a Professional License and trying to figure out how to fix these problems with internationalized strings.
How do I do it with a Professional License. I can't seem to edit the theme layout.
In wrapped.png, text above the progress bar is wrapped.
In truncated.png, its easy to spot.
Thank you in advance.
Re: Professional License - Fixing Truncated and Wrapped Text
Can you please tell me which is the button displayed in the "truncated.png" image (on which dialog is it placed)?
To resolve the problem from the "wrapped.png" image, you can go at the path below, open the "UI.aip" file in a text editor (i.e. Notepad++), search for the "StatusLabel" string and increase the value of the "Width" attribute found on the same row (i.e. from "45" to "60"):
C:\Program Files (x86)\Caphyon\Advanced Installer 11.8\themes\surface\fragments
Then reopen and rebuild the project.
jonathan.reyes1
The button is in VerifyReadyDlg. I will try your solution and get back to you. Thank you.
Oh Master, how about my other issue?
To fix the problem displayed in the "truncated.png" image, you can open the same file as above, search for the "Dialog_="VerifyReadyDlg" Control="InstallButton" string and also increase the value of the "Width" attribute found on that row.
jonathan.reyes1
The text wrapping was fixed, but the fix for the truncated text didn't do anything. I will try a larger value next time.
