edgsoccer
Cannot find Path Edit with Ellipsis
Hello, I cant find on the Path Edit with Ellipsis on the Toolbox. Help please
Re: Cannot find Path Edit with Ellipsis
I'm not sure I fully understand your scenario. Can you please give us more details, maybe exemplify?
edgsoccer
here is a image of the path with ellipsis
path with ellipsis.JPG (10.68 KiB) Viewed 4984 times
In order to achieve what you want you should add (from the toolbox) two UI controls: a path edit and a push button (positioned in the right side of the path edit control). Then, all you have to do is to edit accordingly the "Text" field (from the "Properties" right pane) of the above push button.
Also, you can take a look on our "Browse For Folder" how to which could be useful for you.
If there is anything we can help you with just let us know.
edgsoccer
ok i used the button to call the child window BrowseDlg but i'm getting an error "The specified path '' is unavailable.
Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
