My installer needs to be able to install even if it its already installed.
Basically right is i install once its great works fine.
When i try to install again with the previous install still there, i get an error saying i need to remove the previous installation first.
I need to remove this error and make my installer overwrite previous installation or at least ask if the user wants to overwrite previous install something like that.
Or maybe run silent uninstaller and then run the install?
Is this possible using adv. installer?
Thank you very much for your reply.
Sincerely,
Diego.
