ozgekaya
IIS binding priority
I'm setting my web application on IIS to use 3 bindings. 2 http,1 https. There are no priority settings at the IIS Binding Page of Advanced installer. I want to take https binding with least priority (at the bottom of the list) but however I try the https binding appears at the top of the list causing my web services try to run with https binding.
Is there anything I am missing here?
Özge
Re: IIS binding priority
Hello Özge,
I'm afraid I don't fully understand what you are trying to achieve. Can you please give us more details (maybe exemplify a bit) about this?
Also, can you tell us how would you do that (set bindings priority/order) within the IIS manager (maybe attach some screenshots)?
ozgekaya
I'm trying to take the binding of https at the last position on the Site Bindings list of IIS Manager. I can do it manually by removing the entry and re adding it. New entries go at the end of the list.
When I use my installer the https binding is appearing at the top of the list. So all websites, services try to use the first binding as default. I want it to be http.
Özge
Hello Özge,
Unfortunately, we don't have support to install the web site bindings in a specified order. I've added this improvement on our TODO list and maybe it will be available in a future version of Advanced Installer. Thank you for your suggestion.
ozgekaya
Hello Daniel,
Is there a workaround to achieve what I need? It's still causing some issues on the installed product.
Hello Özge,
The only workaround would be to try creating your own custom action which will set the web site bindings.
