jimjankowski
Advanced Installer 11.8 Evaluation Crashing on Acrobat X
We are in the process of evaluating Advanced Installer as a replacement for Flexera AdminStudio. When trying to create a new transform for Adobe Acrobat X Standard (10.0.0), Advanced Installer 11.8 crashes with the following error when trying to open the corresponding MSI...
Unable to find row with id: trialencoder.dll.70DBED24_B579_40CB_AB0B_F1221A3E9EC5 in table: File.
Advanced Installer 11.8 build 62156
*** Stack Trace (x86) ***
[0x763a4598] RaiseException()
[0x7440872d] CxxThrowException()
[0x00e3556d] -----
[0x00cb0000] MODULE_BASE_ADDRESS
Screen shot is also attached. Note that this the full Standard version of Adobe Acrobat not the Reader.
Any assistance would be greatly appreciated!
JJ
jimjankowski
Re: Advanced Installer 11.8 Evaluation Crashing on Acrobat X
Similar problem with Acrobat XI...
Unable to find row with id: fcdt in table: Extension.
[0x76b14598] RaiseException()
[0x7426872d] CxxThrowException()
[0x00672552] -----
[0x0029835d] -----
[0x006f982f] -----
[0x006f978d] -----
[0x00671814] -----
[0x00e02218] -----
[0x005bcde4] -----
[0x005b9d3b] -----
[0x00225c2f] -----
[0x0052157b] -----
[0x0052112d] -----
[0x00521145] -----
[0x006366ad] -----
[0x00230039] -----
[0x015739de] std::_Init_locks::operator=()
[0x01573f04] std::_Init_locks::operator=()
[0x015cba80] std::_Init_locks::operator=()
[0x0157ed21] std::_Init_locks::operator=()
[0x00220000] MODULE_BASE_ADDRESS
Both were running on a clean packaging VM (VM is running Windows 8.1 Update 3 with the latest Microsoft updates only).
JJ
Hello Jim and welcome to Advanced Installer forums,
I've tested your scenario and I've replicated the described behaviour.
I've forwarded this to the development team. This is currently under investigation. As soon as I have a conclusive answer, I'll get back to you.
jimjankowski
Thanks Dan!! Appreciate the quick response!
You're welcome Jim,
Indeed, this seems to be an Advanced Installer issue. A fix will be available in the next version of Advanced Installer, thank you for bringing it to our attention.
Also, until then if you need this fix you can send us an email to support at advancedinstaller dot com and we can send you a RC containing this fix.
This was fixed in version 11.9 of Advanced Installer released on March 17th, 2015.
