Vijesh
Activating Windows Features
Dear Team,
We have been using AI for quite some time. In AI version 11.4.1 we had created one application where it will install windows features. As of now we are using AI 11.8 and have taken same project which was built in 11.4.1, version for which once after the pre-req is installed it never activates the windows features.
Image one shows the windows features which is been selected in AI.
Image 1
Image 1
image two show the error while installing the application.
Image 2
Image 2
router error.PNG (7.8 KiB) Viewed 5355 times
image three :- have checked the options in windows where it options shows its not checked.
image 3
image 3
Router Windows Features.PNG (49.02 KiB) Viewed 5355 times
Now said all this, I took the exe which was created with help of AI 11.4.1 it works without any problem. By this we can rule out that the problem in OS. If i manually check all the options required for IIS then it will work, which I want this is to be done by AI as earlier.
Can you please suggest on how to get this resolved.
Vijesh
Re: Activating Windows Features
Sorry forgot to attach logs for AI 11.8
Router Error.rar
log file
(4.05 KiB) Downloaded 273 times
I'm not sure why you encounter this problem, I tested the scenario on a "Windows 7 x64" machine using the latest version of Advanced Installer (11.8) and the IIS feature was enabled as expected.
Please make sure that the OS that you try to install your package on, is checked in the "Target Operating Systems" list of the windows feature bundle in your project.
If the behavior persists, can you test the scenario on multiple clean machines?
Vijesh
Hi Eusebiu,
"Please make sure that the OS that you try to install your package on, is checked in the "Target Operating Systems" list of the windows feature bundle in your project"
[ YES, Have targeted the OS ]
We always test with new OS which includes latest windows updates. If required I can provide u both version of AIP.
Yes, please send us the AIP files to support at advancedinstaller dot com, so we can take a look of them.
Meanwhile, can you please download the attached debug DLL file, copy it in the "C:\Program Files (x86)\Caphyon\Advanced Installer 11.8\custact\x86\" folder then rebuild and retest your package? It will create a "C:\AI_WinFeats.log" file that you can send to us, so we can better investigate the problem.
WinFeaturesDebug 11.8.zip
(726.9 KiB) Downloaded 271 times
Vijesh
Hi Eusebiu,
Sure We will do as requested, In the meanwhile we tested the same installer in windows 8.1 Pro and we dint face this problem.
Vijesh
We placed the provided dll in the specified path but there was no logs generated as mentioned when we rebuilt the project.
Will be sending both the AIP's as requested.
Did you also try to install the rebuilt package? The log file is not created during the rebuild, it is created when you try to install the package. After the rebuild you can install the package on any machine and that log file should be created on that machine.
