NovaES
Detect and finalize processes if they are executed
Before we begin, I want to congratulate the developers of this program. I have a couple of days working with him and am about to buy a full license.
Before I wanted to solve a couple of questions to put them into practice in my installer.
1) As I can make the prerequisites are required to install. If they are not installed no longer continue with the installation.
2) Once you uninstall or update the program, I wonder if any of my programs executable file is open and what is it complete. How I can do this?
I would appreciate an answer, I'm anxious to finish testing this software with these questions you have.
Re: Detect and finalize processes if they are executed
Thank you for your kind words and interest in Advanced Installer.
For this, please make sure the Continue with main installation even if the prerequisite is not installed option is disabled in the Prerequisite Properties Tab.
If you received the file in use dialog, then please note that this dialog ("FilesInUse" on XP and "MsiRMFilesInUse" on Vista) is shown automatically by Windows Installer during the InstallValidate standard action when the installer checks if any file is in use and if so, it displays that dialog.
This dialog can be avoided by running a Detect and Stop custom actions before the install/uninstall process which stops the processes which use the files.
Please take a look on the Detect or stop a process How-to article which may be useful to you.
Please let us know if that helped, otherwise give us more details about your specific scenario.
NovaES
Hi thanks for answering.
I could do without problems from the prerequisites. The only thing I did not clarify me is my second problem.
I fail to understand the help of the website. Could you give me step by step and with some screenshots to make it to detect the process is executed and if I finish it?
What else wanted to ask another question, how I can edit the text color of a label of a dialogue? I'm looking at the faqs and I can not find it.
In another question, I could say as I include a dialogue to include the terms and conditions of the program in an RTF file?
Thank You
NovaES
Hi Dan,
Hope it's not too much trouble the answer above. Hope you can help me with any questions raised him.
Please take a look on the Tutorial: Detecting and stopping multiple processes forum thread or on the Checking for the running process and terminating the same forum thread where you can find step by step details how this can be implemented and useful samples.
[..] how I can edit the text color of a label of a dialogue? I'm looking at the faqs and I can not find it.
In the Text Style Tab from the Themes page you can create new text style or edit existing ones.
Then, in the properties view of the related control in the Dialogs page, you can set the text style for the related control. Please see the attached image for your reference:
SetTextStyle to a Control.png (117.51 KiB) Viewed 12572 times
NovaES
Hi Dan,
He has done much help. It ends smoothly and works all right. Before closing the post and mark it as resolved, Give you two questions I would like more.
1º- Is it possible to do that when the installation or maintenance of the program to start, play a file where the application is installed with a command? For example, MyApplication.exe (inside the Program Files folder with the following command /unins)
Would it be possible to run the file with a command and expect it to close when it detects continue uninstalling?
2º- How do I add the file Terms and conditions installer? I found a part, but when I compile error that tells me only MSI. I'm doing the .exe installer only, not if it influences or has to be done on a MSI package.
Thank You
In order to launch a file, you can use the predefined Launch file custom action. From the custom actions properties, you can set its Execution Stage Condition, according to your scenario.
If you want to add an EULA to your installation package, please follow the steps from the How do I add an EULA to my package? article.
If you have any questions, please let us know.
NovaES
Hi Dan, thanks for responding.
I did not clarify me to help me execute a file system with a command and when finished to continue with the task of maintaining the installer.
Is there any tutorial done in the community?
Have you tried using the Launch file custom action to launch your .EXE file? Through the command line field you can pass command line switch to the related .EXE (e.g. unins).
From the Execution Stage Condition section of the custom actions properties you can select when your custom action will be executed.
Please let me know if that helped, otherwise give me more details about your specific scenario.
NovaES
Hi Dan,
I try to follow the help but I can not understand how to do it.
NovaES
Could you help me?
Thank You
Hi Nova,
I'm not sure what have you tried and what behaviour you had encountered.
To launch the related file, you can use the Launch file predefined custom action. Since the the File to launch: field from the custom actions properties is of Formatted Type then you can a reference to the related file.
You can use the below image for your reference.
LaunchFileCA - Sample.png (44.47 KiB) Viewed 12407 times
Let me know if that helped.
NovaES
hi thanks for replying.
When it starts, I skip a notification that has not been able to execute the file or something and contact the package manager. I do not remember the message but something tells me the alert and the package fails to be uninstalled or installed.
I expect an answer thanks
NovaES
They could help me, thanks
NovaES
They could help me thanks
