El-ahrairah
[|AI_AIP_FOLDER]\SetupOutput "Invalid Folder Path"
I have occasionally successfully used this output folder path (on the Media page) on some projects, but I have to say that that success has been intermittent:
IN some projects, I have been able to use the parameterized path with no problems. In others, it gives me the error (see attached screenshot) "Invalid Folder Path".
In some cases, I have literally copied that text from one project to another, and it solved the problem.
For the current setup project I am working on, I cannot solve the problem; every attempt results in the same error.
The indicated folder DOES exist on disk.
Screenshot 2015-02-24 21.00.41.png.jpg (108.1 KiB) Viewed 10741 times
El-ahrairah
Re: [|AI_AIP_FOLDER]\SetupOutput "Invalid Folder Path"
Additional info:
After changing the Package Type from "MSI with resources next to it" (which was actually an incorrect setting for this project) to "Single EXE Setup", the output folder path "[|AI_AIP_FOLDER]\SetupOutput" works.
So, problem is solved, though I do not understand why.
Indeed, this seems to be an Advanced Installer issue which we will investigate and try to fix in a future version of Advanced Installer. Thank you for bringing it to our attention.
The problem appears because the [|AI_AIP_FOLDER] property is sometime resolved ending with the "\" character (in this case two "\\" characters are added to your path where you already added one manually), sometimes it does not end with that character and your path may contain no such character, if you do not add it manually, as in the examples below:
  • D:\\SetupOutput
    D:SetupOutput
ryan.r.corum
I am having this issue as well.
The error occurs when using a UNC path for the output folder. This used to work in previous versions and no longer does. Same error when using the full path or the variable mentioned already.
Thank you.
JPP
ryan.r.corum wrote:I am having this issue as well.
Thank you.
Yeah, I have the same problem and have started a thread about this yesterday morning. No answers so far.
http://www.advancedinstaller.com/forums ... =2&t=33708
Since I need to have my packages built everyday and couldn't wait for an answer I changed my build procedure to build locally and then copy to my UNC path.
Can you please give us more details about the error you get when using an UNC path? Maybe attach a screenshot. Do you consistently replicate this error in multiple projects or it is happening sporadically?
Also, please make sure that the current user (under which the Advanced Installer application runs) has write permissions on the related UNC path.
Marie
I have write access with justice.
But, the person in charge said the same thing over and over again.
I see you dont listen seriously to our issue.
Please understand that we are really in trouble.
Best regards.
Hello and welcome to our forums.
I'm not sure why you encounter this problem. There is, indeed, an Advanced Installer limitation, so that the "-" (dash) character is not allowed in the name of the server (e.g. \\server-name\). This is already on our TODO list, so we will remove this limitation in a future version of Advanced Installer. Sorry for the inconvenience.
Is this your case, too? If not, can you please send us a screenshot of the error or the full path that you want to use in that field?
Marie
HI, Support team.
Our issue is settled at last.
The Server name we want to use is "\\Nas-Srv1\Sheard\...".
We hope that you will fix it urgently.
When will the issue be fixed??
Best regards.
This will be fixed in the next version of Advanced Installer that will probably be released at the end of January 2017.
This was fixed in version 13.6 of Advanced Installer released on February 15th, 2017.
