prasadus92
Manufacturer and version is not set for msi while installing
I have created an Add-In installer using Advanced Installer. When I try to push it using SCCM, in the Create Application Wizard, under General Information, I am seeing only the name of the product getting filled. Other attributes like Manufacturer, Software Version are not filled. I have to manually enter these details. I have seen for some other applications, these fields get filled while pushing through SCCM. Is there any specific settings or options in Advanced Installer that I need to use to make this happen? I have attached the screenshot.
Thanks in advance.
SCCM Install
SCCM Install
Re: Manufacturer and version is not set for msi while instal
I've tested the scenario and indeed I can replicate the behavior. Please give us some time so we can investigate this and I'll get back to you with as soon as we have a clear answer.
Thank you for your patience.
prasadus92
Hi Daniel,
Thank you for your reply.
I will be waiting for the further response.
Prasad
Hello Prasad,
We have further investigated this, but unfortunately we weren't able to find out any Microsoft documentation about what flags/properties should be set in an MSI database so that the Configuration Manager automatically detects the Manufacturer and Software version. Also, we have tested the scenario with an Microsoft MSI (SSCERuntime-ENU.msi, the installation package of the "SQL Server Compact 3.5") and in this case the behavior was the same. The Configuration Manager wasn't filled in any info in the related fields.
In order to investigate this further, can you please send us to support at advancedinstaller dot com a download link of an MSI for which the Configuration Manager successfully detects the related info?
prasadus92
Hi Daniel,
Thanks for your support.
As you indicated, we have to explicitly specify these details in the General Information wizard. I also tested with other MSI like JDK installer.
The same is mentioned in the following MSDN articles:
http://blogs.msdn.com/b/scstr/archive/2 ... _2012.aspx
https://technet.microsoft.com/en-in/lib ... 82159.aspx
Prasad
You're welcome Prasad.
