GhostProtocol
Set users group to have modify rights
I trying to give the users group modify permissions to the directory by right clicking said directory, choosing properties, and setting "Users" to modify in the permissions tab, I have also set the domain to [%USERDOMAIN] amd username to Users - however upon installation the users group does not have modify rights. I need to be able to give local users & domain users modify rights to one of the folder that are installed. any help would be fantastic! Thx!
Re: Set users group to have modify rights
Can you please leave the "Domain" field empty and test again the installation? This field shouldn't be set when the target user account is a regular account. For regular user accounts this field should be empty.
Let us know if this helped, otherwise please give us more details about your scenario.
GhostProtocol
I have tried with both empty and with a domain there.
Our program writes to a directory in the program files which I know is bad practice but doesn't change the fact that it does..
We have to manually set the permissions on the product directory to give the users group full rights so when a user runs our product the program can write to the product directory in the program files directory, by default UAC doesn't allow this so the users group must have rights on the directory.
I am trying to build the installer to do this manual set up for us.
Thank you!
In order to achieve this you should configure the "Permission" tab of your folder like this:
  • Domain:
    Username: Users
    Permissions -> Full Control: checked
Let us know if this helped, otherwise please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate its settings and give us more details (maybe attach some screenshots) about the behavior you are encountering.
GhostProtocol
How do I send you a PM? I have a .swf video showing the issue that you can play using Google or IE and the aip to look at. Never mind, I just saw the email in there, guess I was skimming :)
Thanks!
GhostProtocol
email sent
aveen
Please Can I know how this issue it is solved?
The permissions weren't installed because the component, containing the folder on which permissions were set, it wasn't installed during installation. The parent feature of the folder component wasn't selected for installation, therefore the permissions weren't set.
If you encounter any issues please give us some details about your scenario which could help us to isolate and investigate your case.
aveen
Thanks Daniel.
I solved giving both permissions full control over Folder and over Files to be installed. Must be set username on users.
Hope this help someone
Bye
You're welcome.
Thank you for contributing to our forums.
