meysam
specify QuickSelectionList per feature
i want create setup client server type and my senario is :
2 feature create by wizard -> 1-client & 2- server
2 newdlg added per client server --> newdlg_client for installmode="client" and newdlg_srv for installmod="server"
2 QuickSelectionList control each newdlg1,2
and my question is:
how config for each newdlg just show a feature in QuickSelectionList and The other feature hide.
for exam: in newdlg_client control QuickSelectionList_1 just show client feature and in newdlg_srv control QuickSelectionList_2 just show server feature.
Re: specify QuickSelectionList per feature
The Quick Selection Tree control will list all features from the Organization page (of course if the feature is scheduled to be displayed). So, you cannot implement your scenario using our predefined support.
In this case, you can create your own custom dialogs which implements this.
Please take a look on the How do I show a custom feature selection dialog? article with related information for hints and guidance.
meysam
i read your taturial and in section Install Behavior from Organisation define condition this way :
select radio button "not installed" and set "CHECK1" in texbox conditon. but not worked
please check attachment file.
in the end you'll need to define the features for your project in the Organization Page:
"Feature 1" with the Identifier Feature1 and condition CHECK1
"Feature 2" with the Identifier Feature2 and condition CHECK2
"Feature 3" with the Identifier Feature3 and condition CHECK3
screenshot from organisation setting
Your Application.aip
sample project
(22.15 KiB) Downloaded 257 times
Hi
As far as I can see, you perform the requested changes in your project. It seems correct.
but not worked please check attachment file.
I'm not sure I fully understand your scenario. Can you please give us more details (maybe exemplify)?
