edgsoccer
Can't Upgrade or Unistall
I was able to create a path to install some files to the personal folder path. but now i cannot upgrade or uninstall the installation. take a look at the errors that we are getting. :!:
upgrade fails...
upgrade fails...
Try to delete
Try to delete
personal folder.JPG (11.88 KiB) Viewed 2079 times
Re: Can't Upgrade or Unistall
I'm not sure why you encountered the this behavior.
