matt123
Product shortcut name
This is probably (hopefully!) a very simple question, but I cannot work it out.
I have a new project, and the product name is configured in the Product Details tab to how I want to see it in the shortcut menu (also the W8 tile). The problem is that I am not seeing this when the product is installed - instead, I get <application_executable_name>.exe. It doesn't look great.
I didn't get this issue with my earlier projects, and I don't remember doing anything differently.
My product version is 11.3 and my update subscription has expired, so I am stuck on this for a while at least. Earlier projects might well have been created with an earlier version of AI, so I do hope this is not an issue introduced by an AI update - if so, how to revert?
thanks,
Matt
Re: Product shortcut name
Hi Matt,
We are not aware of such an issue.
However, in order to have a better view about this, can you please send us the .AIP (project file) and a printscreen with the encountered behaviour to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
matt123
Hi Dan,
Thanks for your response - email sent.
Matt
