Aeroclassics
Machine specific licensing
I have read just about every forum post, every web page and the user's guide but this licensing thing still does not work. I have the latest version of AI. I downloaded the sample C# app and built it into a AI installer. I changed the key to match the installer. I can run the app and under help select register. The target machine will never have an email program on it. 99.99% of the time the software is loaded onto the PC by us as we have hardware to install. So if I click the computer ID link in the Register dialog naturally that fails. It cannot be copied, so I wrote it down and went to AI. In the installer for the Trial App I clicked Generate Registration Keys and typed that value into the cell in the grid. Hit return and it get a key. I copied and pasted that key into the demo app and it always tells me it is not a valid key. So am I doing something wrong or is this feature broken for machine specific keys?
Doug
Re: Machine specific licensing
Hi Doug and welcome to Advanced Installer forums,
I'm not sure why you encountered the this behavior.
In order to have a better view about this, can you please send us the .AIP (project file) to support at advancedinstaller dot com so we can investigate it? If it contains confidential information you can send us a small test project which reproduce this behavior.
By the way, please make sure you copy the full license preview. For example, if the license template from the Licensing Registration Tab looks like this:
when entering the license, you should have something like:
Signature: mHbiggiAVse4hJ7nvitlKW@BpBkIVwGvtNDTzN7VkdXxzvzDWS5WTCpUe2eomWo3
