HBHLEVY
Two n00b questions
I'm a new user of this software (Enterprise) - I have a few questions
1. Is there a way to do both "Limit to basic user interface" and still have it launch the program after install?
2. Is there a way to fire the install of a missing software launch condition? For example if .net 4.5.2 is missing, can it fire off that install (much like InstallShield LE) or does the user just have to install it separately?
Re: Two n00b questions
Yes, this can be done trough the custom actions approach.
For example, you can add the predefined Launch file custom action as a custom action with sequence.
Please make sure you add the custom action after the Finish Execution stage from the Install Execution Stage. Use the below image for your reference:
Yes, this can be done through our Prerequisites support. If your application needs the 4.5.2 version of Net Framework then you can add in from our predefined list of prerequisites.
Please take a look on the Add Prerequisites article with related information for hints and guidance.
