rahnajoseh
copy files using command line options
How to copy files using command line options while installing.
thanks in advance
rahna
Re: copy files using command line options
Hi rahna,
I'm not sure I fully understand your scenario. Can you please give us more details (maybe exemplify)?
rahnajoseh
Hi Dan,
Thanks for the reply.
When we run our installer in citrix environment from elevated administrator account , we are not able to copy 2 files .
windows environment , its working fine.
So is there any way to copy the files to particular folders by command line options or by calling any batch file in custom action etc.
If you want to launch a .bat file, then you can use the predefined Launch File custom action.
For details, please check the How do I launch a CMD or BAT file? article with related information for hints and guidance.
rahnajoseh
Problem with running batch file after installation
we are facing one issue while uninstalling our application.
During uninstall stage I have added one custom action to launch .bat file.
But i am getting one error while uninstalling. Screenshot attached.
Can you please give the resolution for this.
Regards
Rahna
Hello Rahna,
I'm not sure why you encountered the this behavior.
