Alex99
Uninstall CustomActions on upgrade
Hello. I use Advanced Installer v11.7 build 61774. I use upgrade by upgrade codes.
I have some Custom Actions on uninstall that cleans system. When I remove application from Control Panel->Programs and Features Custom Actions are executed. But when I upgrade my application they do not execute. I need they was executed. I use next condition for it:
I read http://www.advancedinstaller.com/forums ... =2&t=26076 and tried modify InstallExecuteSequence to ( Installed AND ( REMOVE = "ALL" OR AI_INSTALL_MODE = "Remove" OR UPGRADINGPRODUCTCODE)) but it didn't help.
Thanks in advance,
Alex
Re: Uninstall CustomActions on upgrade
Hi Alex,
The custom action should be executed during an upgrade if you check the "Upgrade" checkbox from the "Execution Stage Condition" section displayed in your second image. Can you try this and see if it works? First, make sure that you undo the modification that you did in the "InstallExecutionSequence" table.
