meysam
order for install feature based?
how order install feature- based of prerequisite ? i have 3 feature- based program and i want install by my order
thank you
Re: order for install feature based?
The feature based prerequisites will be installed in the order they appear in the list, as they are added to the package. You can select a prerequisite to be installed before another one by moving it up in the list, as you can see in the attached image:
MoveUp - Prerequisite.png (40.74 KiB) Viewed 2840 times
Based on the above list, the installation sequence will be the following:
  • 1) Visual C++ 2010 SP1 x64 (MFC Security Update)
    2) Visual C++ Redistributable for Visual Studio 2012 x86
    3) Visual C++ 2010 x86 (MFC Security Update)
Also, you can see the installation sequence of the prerequisites in the AI_PreRequisite table from the Table editor view (check the Sequence column).
meysam
thank you very much Dan.
ok, my problem is fixed by your help but can you help me for another problem?
in organization tab i have 3 feature and in file and folder resource i have regular folder and put in my sample file.
i want just in install mode server (installmod="server") my folder created in target pc and other feature such as client & MainFeature my folder don't created.
list feature:
1-MainFeature
2- client
3-server
best regards
meysam
Hi Meysam,
In this case, you can move the related component under the Server feature using a drag-and-drop operation. This way, the related component will be installed only if the Server mode will be selected for installation.
