I'm using Enterprise 11.3 and my project has enhanced UI on install using the granite theme. When doing the removal from add/remove programs it is triggering the dialog from Windows Installer stating "Are you sure you want to uninstall this product?" I know I can change the setting to used enhanced UI always, but during uninstall I don't want to see the maintenance dialog etc.
How can I get the behavior like one of our other projects which is also using enhanced UI, but with classic theme. With that project upon uninstall from add/remove I'm given a different dialog titled Programs and Features and asks "Are you sure you want to uninstall XXX" where XXX is the name of the product. With a check box "In the future, do not show me this dialog box."
Thank you.
