ElectronShepherd
Installing a product with a long name
One edition of our product has a long name, and it looks like the name is being truncated during installation. It's only a "visual" problem - the full name is preserved in areas such as Add/Remove Programs. When running the install, it seems that the product name is being unnecessarily shortened. The attached images will hopefully make this clear. The stages before the actual processing use all the space, but when processing, the product name is shortened more than it needs to be.
Is there some way I can get AI to use all the space on the wizard header for the text?
Re: Installing a product with a long name
Indeed, this seems to be an Advanced Installer issue. A fix will be available in a future version of Advanced Installer. Thank you for bringing it to our attention. Until then, here is what you can try.
You can easily fix this using the Dialog Editor by changing the width for the related control. Please note that the dialog editor requires at least an Enterprise project type.
If your project (license key) is below Enterprise, then you can modify the internal fragment of Advanced Installer. So, in the installation folder of Advanced Installer (the default one is C:\Program Files (x86)\Caphyon\Advanced Installer 11.8\themes\classic\fragments), please locate the UI.AIP fragment. If you are using other theme, please select the corresponding theme to make the change.
In the UI.AIP fragment, please locate the following row:
<ROW Dialog_="ProgressDlg" Control="Title" Type="Text" X="20" Y="15" Width="200" Height="15" Attributes="196611" TextStyle="[DlgTitleFont]" Order="900" TextLocId="Control.Text.ProgressDlg#Title"/>
You can easily increase its width attribute e.g. Width="280".
ElectronShepherd
That worked great. Thank you.
You're welcome,
This was fixed in version 12.8 of Advanced Installer released on March 23rd, 2016.
