meysam
warning message about ODBC
what is this message ? this message When appear that setup start set sql server connection and execute scripts.
how control this msg? i want not show this msg.
for first installation not show this msg but after first installation this msg showed.
meysam
Re: warning message about ODBC
solved
by this way:
find which section or script in server configuration Causes warning msg :
1- change width and height control action text in progress dialog
2- change subscribed event to
Display installation action details (enhanced ui only) Text
3- save and bulid project
4- run again for show warning msg and read details error in action text
finally this error Causes by one script that create user for my database :
1- google it (t sql check if user exist)
2- find this aticle:
http://stackoverflow.com/questions/672 ... dy-exists
my script :
CREATE LOGIN [VNLite] WITH PASSWORD=N'********', DEFAULT_DATABASE=[master], CHECK_EXPIRATION=OFF, CHECK_POLICY=OFF
    EXEC master..sp_addsrvrolemember @loginame = N'VNLite', @rolename = N'sysadmin'
point: for first installation this msg not show because this TSQL executed successfully username in database but for Next time show this msg.
solution: change TSQL and use IF statement
If not Exists (SELECT name FROM sys.server_principals WHERE name = 'VNLite')
BEGIN
    CREATE LOGIN [VNLite] WITH PASSWORD=N'**********', DEFAULT_DATABASE=[master], CHECK_EXPIRATION=OFF, CHECK_POLICY=OFF
END
best regards
meysam
Hi Meysam,
I'm glad you solved the problem. Thank you for sharing the solution with us, I'm sure it will help other users in the future.
