meysam
translate PrepareDlg
i want translate this dialog but not find strings in project string & default strings tab.
how translate this dialog?
Re: translate PrepareDlg
That dialog is automatically translated for most languages. However, if you want to replace that text with your own text, you can write your text in a RTF file, then go in the "Dialogs" page, "Bootstrapper UI" section and use the "Override information text with .rtf file" option.
If you have more languages in your package and want to use a different RTF file for each language, you can go in the "Translations" page, "Project Strings" tab and edit the "BootstrapperOptions.IntroTextPath.GlobalOptions" row by writing the appropriate path on each language's column.
meysam
there is no "BootstrapperOptions.IntroTextPath.GlobalOptions" in project string.
(select all translate project segment and sort by column localization Id)
That row appears only after you use the "Override information text with .rtf file" option from the "Bootstrapper UI" section as I mentioned in the previous post.
