meysam
error after translate
after translate project string tab this error show in during installation wizard
how fix this?
Re: error after translate
To fix this problem, you can go in the "Translations" page, "Project Strings" tab, use the [Select...] button from the bottom of the page and select the "Registry" checkbox from the dialog that appears, then press [OK].
After you do this, the localization IDs related to the registry will appear in that page and you can translate the "Registry.Name.InstallLanguage" and "Registry.Key.ProductCode" rows that are displayed in that dialog.
meysam
i'm translate two localization id but new error show in duration installation
meysam
after new error i'm clear translate 2 localization id and clear all select segment in project string tab and clear productcode key in registry setting and build project.
fix problem.
I'm glad you solved the problem. Just let us know if you have any other question.
