rtischer8277
'Preparing to Install' failure
I recently updated AI to 11.9, but when I click on the resulting .msi file I get for a half a second a Windows Installer screen that says 'Preparing to install' which goes over to This installation package could not be opened. Contact the application vender... (that would be you). See attached for a glimpse of the error screen followed by the stationary error screen. Attached the .msi file as well.
Hiveware debug.aip
(18.44 KiB) Downloaded 264 times
Preparing to install error.png (47.57 KiB) Viewed 3124 times
Re: 'Preparing to Install' failure
Have you tried to clean up the cache folder (it should be next to the .AIP(project file)) and then Rebuild of the project?
Does the behaviour still persist?
rtischer8277
I switched install build machines and the new one creates the install from the D: drive. But even though my Install Parameter had [WindowsVolume] in the path, it still created the .msi file on the C: drive. I wrote out the pathname instead.
