waldedg
How to send Install Command Line options
I have a Prerequisite package I would like to run during my install package. I would like to make it a silent install as well as not have it ask the user for a restart. The installer has command options for these. If I were to run it from the command line it would look like this:
.....\setup.exe /qb /acceptlicenses yes /r:n
Where the:
/qb is quite and basic
/acceptlicense yes is for automatically accepting the license
/r:n is for No Restart
I currently have in the Basic UI box: /qb /acceptlicenses yes /r:n which is not working. The installer runs but the options have NO affect on how it runs.
Any help would be greatly appreciated.
Thanks, Doug
owe911
Re: How to send Install Command Line options
maybe you can try by setting ccommands in here .
As owe911 mentioned above, you can go in the "Setup Files" tab of your prerequisite and write your package command line in the "Install Command Lines" fields.
For instance, if you want your prerequisite to be installed using that command line, only when the main package is installed in silent mode, you can write your command line in the "Silent (no UI)" field: /qb /acceptlicenses yes /r:n
If you want your prerequisite to use that command line every time, you can write its command line on all the "Install Command Lines" fields.
waldedg
Thank you very much that was very helpful.
Thanks, Doug
You're welcome. Glad to help.
Just let us know if you have any other question.
