owe911
HOW A EDIT SHOW THE SYSTEM PROPERTY
hi , i came into an problem
when i diy a diaglog ,there are many edits to write,could the Advcanced Installer help me fill this edit by getting the system property?
eg:
i could let the edit show an default number like this ( i manual input theses numbers!)
OR what should i do ,when i wan to write something or variables in "default value" to show the correct computername?
Re: HOW A EDIT SHOW THE SYSTEM PROPERTY
The ComputerName property is the computer name of the current system. The installer sets this property at runtime.
Since the Default Value property field is of Formatted Data Type, then you can add a reference to the related property. e.g.
[ComputerName]
owe911
Dan wrote:Hello,
[ComputerName]
hi Dan,
that works ,ths
BTW,now i can get all kinds of properties in system property.
if i want to get the ip address or NET MASK or gateway on the current system(consider as win7 system),what should i write in property?
can you give me an example?thanks a lot
You're welcome,
To get the ip address or NET MASK or gateway of the target machine, you need to create a custom action.
Please take a look on the How to get my own IP address in C#? thread which may be useful to you.
In order to integrate your custom action in your installation package, you can follow the steps from the Options to integrate and debug custom actions article.
