pimboden40
XML Config with no XML Escaping
Hello
I have imported my config File in my installer so I can add all the needed settings with the session variables filled during the setup.
One of my Installer steps allows the user to select some folders, that I want to add under the xml-element syncPaths.
so the final xml it should look something like this:
<syncPaths>
  <syncPath value=''selected_folder_1' />
  <syncPath value=''selected_folder_2' />
  <syncPath value=''selected_folder_3' />
</syncPaths>
each selected folder should create a new syncPath -element
So I set a Session variable called BTS_XML_SYNC and wanted to have this as the text element on the syncPaths element.
A custom Action creates the "sub-elements" and sets the BTS_XML_SYNC with this text.
Something like this:
session["BTS_XML_SYNC"] = "<syncPath value=''selected_folder_1' />\n<syncPath value=''selected_folder_2' />\n<syncPath value=''selected_folder_3' />"
The Problem:
This text gets XMl escaped so I get this result:
<syncPaths>
</syncPaths>
How can avoid the xml-encoding?
Thank you for your help
Re: XML Config with no XML Escaping
I'm afraid that this is the normal behavior. You can take a look on the Keep single quote in XML Value from turning into &apos; thread which debates a similar subject.
If you really want to use the < and > characters, you can follow the steps below:
- create a new "Text File Update" operation next to your "XML Edit" operation and set the same name for it
- go to the "Append/Create" section and uncheck the "Create file with encoding" option
- go to the "Replace" section and write < in the "Find" field and < in the "Replace" field
- right-click under the "Replace" text and use the "New Search and Replace Operation" option
- write > in the "Find" field and > in the "Replace" field, then click OK
- go in the "Table Editor" page, "InstallExecuteSequence" table and modify the "Sequence" value of the "AI_TxtUpdaterInstall" row from "5101" to "5014"
- build and run the project
pimboden40
Worked!!!
You Guys /Girls are fantastic!
Thank you!
You're welcome. I'm glad it worked.
pimboden40
Hello.
After the successful writing,I have another problem with this.
I want to be able to read the Content of this element during the Search -Phase:
I tried to make it with the "normal" Search behavior..
my config file is correct:
but My Session variable is always empty...
all the other session variables are filled..so the search works, except for this special case.
Again..
I'm afraid I do not fully understand your scenario. Can you please mark the XML element that you want to search from the XML tree?
I see that you want to get the text of the "syncPaths" element, but it does not contain any text. Do you want to get the value of one of the three "syncPath" elements that are found under the "syncPaths" element?
