Been on this a few days even after seeing some forum topics on the same topic.
Have Advanced Installer 11.9 trying to install SQL Server 2008 R2 in silent mode.
Have defined the install as a Pre-Install with the install commands as "/qs /ConfigurationFile="[SourceDir]\Data\ConfigurationFileConcept.ini"
Am getting an error in the SQL log - see below.
Have also include the Advanced Installer Log as an attachement.
How do I get the ConfigurationFileConcept.ini to be picked up by the SQL Installation?
Can get the installation OK if do not use any command lines but then have to enter all the SQL Installation Options (which I do not want the user to have to do).
Brian
Overall summary:
Final result: Failed: see details below
Exit code (Decimal): -2068578304
Exit facility code: 1204
Exit error code: 0
Exit message: The configuration file 'c:\166d7d011c8572a705bf1a7b42d135\[SourceDir]\Data\ConfigurationFileConcept.ini' does not exist. Specify a valid configuration file.
Start time: 2015-03-30 23:38:16
End time: 2015-03-30 23:38:52
Requested action: LandingPage
Machine Properties:
Machine name: RBCVM-WIN764
Machine processor count: 2
OS version: Windows 7
OS service pack: Service Pack 1
OS region: United States
OS language: English (United States)
OS architecture: x64
Process architecture: 64 Bit
OS clustered: No
Package properties:
Description: SQL Server Database Services 2008 R2
ProductName: SQL Server 2008 R2
Type: RTM
Version: 10
SPLevel: 0
Installation location: c:\166d7d011c8572a705bf1a7b42d135\x64\setup\
Installation edition: EXPRESS_ADVANCED
User Input Settings:
ACTION: LandingPage
CONFIGURATIONFILE: c:\166d7d011c8572a705bf1a7b42d135\[SourceDir]\Data\ConfigurationFileConcept.ini
ENU: True
FARMACCOUNT: <empty>
FARMADMINPORT: 0
FARMPASSWORD: *****
HELP: False
IACCEPTSQLSERVERLICENSETERMS: False
INDICATEPROGRESS: False
PASSPHRASE: *****
QUIET: False
QUIETSIMPLE: True
UIMODE: AutoAdvance
X86: False
Configuration file: C:\Program Files\Microsoft SQL Server\100\Setup Bootstrap\Log\20150330_233550\ConfigurationFile.ini
Detailed results:
Rules with failures:
Global rules:
There are no scenario-specific rules.
Rules report file: The rule result report file is not available.
Exception summary:
The following is an exception stack listing the exceptions in outermost to innermost order
Inner exceptions are being indented
Exception type: Microsoft.SqlServer.Chainer.Infrastructure.InputSettingValidationException
Message:
Data:
SQL.Setup.FailureCategory = InputSettingValidationFailure
DisableWatson = true
Stack:
at Microsoft.SqlServer.Chainer.Infrastructure.InputSettingService.LogAllValidationErrorsAndThrowFirstOne(ValidationState vs)
at Microsoft.SqlServer.Configuration.BootstrapExtension.ValidateChainerSettingAction.ExecuteAction(String actionId)
at Microsoft.SqlServer.Chainer.Infrastructure.Action.Execute(String actionId, TextWriter errorStream)
at Microsoft.SqlServer.Setup.Chainer.Workflow.ActionInvocation.ExecuteActionHelper(TextWriter statusStream, ISequencedAction actionToRun)
Inner exception type: Microsoft.SqlServer.Chainer.Infrastructure.InputSettingValidationException
Message:
Data:
