meysam
copy folder in common folder 32 or 64 bit
my Supported package types is Supported package types
i want copied one folder in common folder and i want For Type "32-bit OS" or "64-bit OS" this folder copied in :
C:\Program Files\Common Files
or
C:\Program Files (x86)\Common Files
how doing this?
Re: copy folder in common folder 32 or 64 bit
To achieve this, you can go in the "Files and Folders" page and place your files in the "Program Files 64 -> Common Files 64" folder for a 64-bit machine. That folder will be resolved to "C:\Program Files\Common Files" on a 64-bit machine.
Also, copy and past those files in the "Program Files -> Common Files" folder for a 32-bit machine. That folder will bi resolved to "C:\Program Files\Common Files" on a 32-bit machine.
Then you need to go to all those files related components from the "Organization" page and set conditions for those components, so that the files placed in the 64-bit folder will be installed only on the 64-bit machines (i.e. VersionNT64) and the files placed in the 32-bit folder will be installed only on the 32-bit machines (i.e. NOT VersionNT64).
meysam
sorry
i wrong in question.
because my scenario is:
1- if os type is 32 bit : my folder must copy to c:\Program Files\common Files
2- if os type is 64 bit : my folder must copy to c:\Program Files (x86)\common Files
In other words i don't need common file 64.
I apologize. plesase help me
best regards
meysam
Hi Meysam,
In this case you only need to place your files in the "Program Files -> Common Files" folder without setting any condition for them.
