Installer Analytics Reports
Hi everyone,
If you're using our latest support for Installer Analytics and you want to see more reports in your dashboard please reply on this
thread with your favorite ones. Here is a list with the ones already in development:
- Upgrades
- Uninstalls
- Geographic
- OS breakdown
- Application versions
- Errors and failed installs
Re: Installer Analytics Reports
Check out the new reports from Installer Analytics, now you can see how many users install your application (not just how many installations occur),
along with the upgrades and uninstalls for the existent users.
More new reports will be coming up in the next months.
Installer Analytics - New Reports.png (64.57 KiB) Viewed 81657 times
As promised, more reports coming up for Installer Analytics. Now you can check per-version installations, how many fail and what fails, as well as environment information (RAM, OS, screen size, etc...)
ima-aa
The reports are looking good. But it would be great if they could be more detailed.
For example the geo report could go down to province.
greetings
Andreas
ima-aa
it would also be interesting to me if the environment report could be enhanced with a cpu class
I know how much ram is in the pc, but the speed would also be good to know. Maybe that we doesn't get too many details we can say - i3 - 3rd generation, i7 - 4th generation. The clock speed is too detailed for the first sight. but I could think of a drill down.
greetings
Andreas
Installer Analytics allows you to define your own custom reports through the custom properties report.
This functionality is available starting with the 19.4 version of Advanced Installer,
Basically you can get any information in your reports, be it a property set by the user or automatically from a custom action. You have full control how the property is getting set.
Let us know if you have any other suggestions for Installer Analytics.
Return to “Feature Requests”
