owe911
does the edit property support the regular expression?
hi ,
for example ,i get an edit to input the ip address , however i want to example the format when this edit is typed.
there will be an warnnig when the IP is a wrong format .
i search your user guid , there is no suggestion or example in this situation~~
please give me some advice~ths a lot
mihai.petcu
Re: does the edit property support the regular expression?
Actually Windows Installer UI is not that smart to publish such complex events. However, there's a sample Spawn Dialog validation in the Validation of edit box for to accept IP Address thread you can take a look at. By changing the value of the MYPROP property according to the validation logic, you can determine whether the Spawn Dialog is shown or not.
