Hello all,
I'm just new to using Advanced Installer - great product!
I do have a problem now though which I'm hoping is a simple fix. I have created an "MSI from .EXE" project and added various requirements which is all fine. The one issue I am having is that I can't get that .exe to silently install. The .exe does have a /silent switch when run as a stand alone installer, which works as expected and there's no user interaction. However I have imported it with Advanced Installer and created a single .msi with all files inside. When I run it though I can't seem to get that /silent switch to work.
The .MSI install installs everything as it should but it requires user interaction and no msiexec switches apply here. I essentially want a (No UI) install that you would get with a bootstrapper but don't know how I should apply it or where. Is it in the pre-requisites area in the "Install Command Lines" area, if so then what is the format?
Thanks in advance.
