Alex99
UpdateFeaturesInstallStates executes after each dialog
Hello. I use AdvancedInstaller 11.7.1. I use Enhanced use interface. I set run UpdateFeaturesInstallStates after all dialogs but before InstallationStage. But I note that UpdateFeaturesInstallStates runs each time when user moves to next dialog, but I don't need execute it between dialogs. Some times UpdateFeaturesInstallStates can take 20 seconds, as I have many dialoges it lead to significant waste of time and makes UI slow. Can I turn off it?
codesynergy
Re: UpdateFeaturesInstallStates executes after each dialog
Did you add the UpdateFeaturesInstallStates custom action after "User Selection" in the custom actions list (see attachment)?
To stop the "UpdateFeaturesInstallStates" action of being executed on your dialogs you can go to "Dialogs" page and remove the "Execute custom action" control events, which launch the above custom action, added on your dialogs.
Let us know if this helped, otherwise please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate it.
