prasadus92
Customizing the updater UI (given by Updater.exe)
Is there a way to customize the dialogs indicated in the images attached?
These dialogs will be shown during the update install.
Thanks in advance.
Prasad
Re: Customizing the updater UI (given by Updater.exe)
Hello Prasad,
I am afraid this is not possible. The updater user interface is built in and can not be customized. Should you feel the need for a more customized install experience, you can use themes for your installers.
Let me know if this helped.
prasadus92
Hi Dan,
Thanks for the reply.
There is a potential problem here. I noticed that when I click the minimize button, the Window will get disappeared. It will not be in the taskbar entry rather it will be in system tray.
So I am thinking to show a progress bar of my own at the worst case, but I am not sure if there are any callbacks/events from this Updater.exe that indicates me to show the progress. Please let me know if there is a way.
Prasad
Hi Prasad,
You can see my response on the following links from the forums: Allow users to customize the Updare.exe UI.
