Mondq
Windows 8 won't create app drawer shortcuts
Hi there,
I really like your software, but there's one thing I can't figure out:
I create a msi file on PC 1 (windows 8.1)
and then install the software on PC 2 (Windows 8.1)
The software installs fine except, that it does not create shortcuts in the Windows 8 start menu. If I navigate to where the program is installed (C:\programs\...) I can start it by clicking on the exe file
I chose one of the default templates for the installation (see attachment)
Any ideas?
Re: Windows 8 won't create app drawer shortcuts
The Start Screen can be only customized by the user. It seems this is because Microsoft doesn't allow any programmatically customization of the Start Screen.
You can also take a look on the Not able to pin shortcut to 'Start' tile list in Windows 8.1 thread which debates a similar subject.
