jonny
version 12.0 crash
Description:
Problem signature:
Problem Event Name: APPCRASH
Application Name: advinst.exe
Application Version: 12.0.0.0
Application Timestamp: 551d442d
Fault Module Name: StackHash_8191
Fault Module Version: 6.1.7601.18798
Fault Module Timestamp: 5507b3e0
Exception Code: c0000374
Exception Offset: 000cea0b
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Additional Information 1: 8191
Additional Information 2: 8191b326d9374dece81e12e5972cd1b7
Additional Information 3: 03cf
Additional Information 4: 03cfdd98af8dae9eb30baf141f23d392
How to reproduce:
On windows 7 64-bit enterprise repackage AD Instruments Powerlab v5 install as 32-bit using the /ForceX86 command line switch . Powerlab has two applications Chart and Scope.
As an aside I noted that during the repackage two unsigned driver warnings were issued to which I answered install anyway.
After the repackage is finished allow Advanced Installer to auto open the repackaged data. It crashes as above.
Alternately open the .rpk file with the package I will email to you
Environment
I will email you the complete repackage output as a zipped file.
Please let me know if you need further info.
jonny
Re: version 12.0 crash
Sadly your system has rejected the 40MB zip file of the repackage data that would make it easy for you to debug (edited the following for the at and dot):
The following message to <support at advancedinstaller dot com> was undeliverable.
The reason for the problem:
5.1.0 - Unknown address error 552-'5.3.4 Message size exceeds fixed limit'
So I'll attach just the .rpk file here. There's no .AIP file as it crashes before that is created. If there's some other way to get the data to you let me know.
jonny
so I tried uploading the .rpk file and it says "The extension rpk is not allowed." I also tried uploading the entire repackage file zipped but that didn't work either. I'll try to find somewhere to post it for you to download.
Edit: Inspection of the .rpk file showed it to be XML contents so I changed the suffix to .xml and have uploaded the powerlab.rpk as powerlab.xml
Powerlab.xml
(587.5 KiB) Downloaded 288 times
mihai.petcu
Thank you for the detailed error report, our QA team will look into this as soon as possible.
mihai.petcu
Our QA team has tested the .RPK you attached with a couple Advanced Installer versions but unfortunately they were unable to replicate the crash. Now we're trying from another angle. Maybe this can occur when importing right after capturing the installation.
Although our team submitted their registration form a couple days ago to get the package online, it seems the AD Instruments team didn't reply. Can you please send us a download link installation package over e-mail so we can get this done quicker?
jonny
I have emailed you a link to where you can download the complete installation capture from. Please let me know once you have downloaded that so I can remove it from the server. Thanks.
mihai.petcu
Hi Jonny,
The fix for this issue will be included in our next release. Thank you for bringing it to our attention.
jonny
Thanks! That a really fast turn around. :D
I look forward to the new release.
