I'm working on updating our installer (we have the enterprise edition with java products). I've run into an issue which I nor others can seem to get around.
We have two Build targets, one that builds an EXE (single file setup w/ resources inside) and one that builds an MSI (again single file setup w/ resources inside).
The EXE installer has the UAC shield icon on it and always requests admin privileges up front before starting the installer. The MSI does not. I've gone through every menu and tried several different settings of "Run as Administrator" (including the one on Installation Details), but it still requests admin privileges up front. I want it to act like the MSI installer where it only asks for admin privileges when trying to write to a system-protected folder or do something else that actually requires admin rights.
The use case I have is that we want our product to install as either per-user or for all-users. The per-user case with the MSI installer works just fine.
Any thoughts?
