KKap
Folders remain after uninstalling
hi,
System: Windows Server 2012
I have the following problem : I have a service installer built , which is also installed correctly and run .
Only when i uninstall the program, the folder structure and 2 files remains the service has created get , everything else ( files) are deleted ( Uninstalled )
I've already tried:
- Uninstall Cleanup
- Folder Properties -> Remove Folder
has any of you any idea ?
Re: Folders remain after uninstalling
To get a more accurate picture of your installation scenario, can you please send us the .aip (project file) to support at advancedinstaller dot com and a verbose log of the uninstall so we can investigate them? Also, please specify which are the folders and files that are not deleted.
codesynergy
If the service is creating these files after install, then the installer will not uninstall those files (since the installer did not install them). For this scenario, you might try using a new "File Removal" operation as described here: http://www.advancedinstaller.com/user-g ... ialog.html
KKap
sry your solution dont work for my projekt
i have try this (http://www.advancedinstaller.com/user-g ... lders.html) "remove folder"
Remove on: Component uninstall
and the Folders are still there .....
codesynergy
Just to confirm, are you adding file removal operations for each file that is being left over (see attachment)?
