kumarkvs09
Edit XML file
Hi
To Capture the Sql Username and Password I am trying to import and edit the XML file. i have imported the XML file from Files and folder and in edit XML file, I created Username=[USERNAME_PROP] and Password=[PASSWORD_PROP] in Attributes.
Config file:
<properties>
<username>root</username>
<password>root</password>
</properties>
I have given username=root and Password= test in Sql dialogue and in Program files folder the Config file looks to be as
<properties username ="root" password="test">
</properties>
Here i want the node to be replaced and it should be displayed as
<properties>
<password>test</password>
</properties>
Thanks for your help.
Regards
Kumar
Re: Edit XML file
Hi Kumar and welcome to our forums.
In order to achieve this, you need to create two new elements under the "properties" element and name them "username" and "password", then use their related properties in the "Text" field from the "Element Settings" tab (as displayed in the attached image).
XML Settings.png (54.09 KiB) Viewed 2581 times
kumarkvs09
Re: Edit XML file
Hi Eusebiu
I created Username and Password and added properties for the same and it worked. Thank you so much for the support.
Regards
KVS Kumar
Re: Edit XML file
You're welcome Kumar. I'm glad it worked.
Just let us know anytime you have a problem.
