Ruben
Bundle two java versions 32/64 Bit
We want to bundle a JRE so that it is installed in the application folder (i.e. for our application exclusively).
There should be two JRE versions bundled (32 and 64 Bit). Depending on the system, only the right one should be installed.
Is it possible, and which template is recommended ?
Both the "Java" or "Mixed 32/64 bit package" templates provide an aspect that seems required.
Many thanks,
Ruben
mihai.petcu
Re: Bundle two java versions 32/64 Bit
Hi Ruben,
Basically you could use either templates. This logic is this:
- you add your Java product's resources and condition them to 32 / 64 - bit locations and machines
- from the Java page configure two Java Products and bundle each with the appropriate JRE
This way the Java Product defined in the Java page along with its bundled JRE will only be installed when its resources will be installed.
Ruben
Thank you. That seems logically structured and I'm getting warm with it.
