Jebrew
Recovery options for services
In the service control manager, you can set recovery options for the services (retry if the service fails to start properly, how long to wait before retrying, a program to launch on failure...).
I'd like to see those options in the installer (as our service has a bug in the threading whereby it will fail to start once in about 300 installs and would be fine if it could just be set to retry).
Jebrew
gigi
I'm afraid that what you want is not support by Windows Installer. Advanced Installer already implements all options that windows Installer supports about services.
You can read more about what options Windows Installer supports regarding services here:
http://msdn2.microsoft.com/en-us/library/aa371637.aspx
http://msdn2.microsoft.com/en-us/library/aa371634.aspx
Gigi
Gheorghe Rada
Advanced Installer Team
otvald
I second that request!
Currently, I have to instruct the end-user to manually go into the service properties and set the recovery option for the installed service, after the programmes are installed.
It is possible to extend the installer, e.g. look at:
:arrow: http://www.codeproject.com/install/serc ... lerext.asp
Here, this class extends the service installer with "FailureActions.Add" methods... Is there any way to get this functionality into Advanced Installer too?
/Thomas
Ionut
Hi Thomas,
As mentioned above, Windows Installer does not support setting recovery options for services. However, you can use the "sc" command line tool with the "failure" option as a Custom Action.
The Custom Action type will be "EXE with Working Dir" and it can be scheduled under Install. Use the following settings for this Custom Action:
- Execution Properties: "Synchronous execution, ignore return code"
- Execution Options: "Deferred with no impersonation"
- Execution Condition: (Not Installed)
The "Full Path" field will be set, for instance, to:
"[SystemFolder]sc.exe" failure "service_name" actions=restart/60000/restart/60000/""/60000 reset=86400
Test the command outside the installer before defining the Custom Action.
Ionut
Denis Toma
crandom
Re: Recovery options for services
I thought I'd post this here for posterity. I adapted this command to:
sc.exe failure SERVICENAME actions=restart/60000 reset=0
That works fine, except on XP (and possibly Win2k3, although I didn't test there). On XP, this syntax is required:
sc.exe failure SERVICENAME actions= restart/60000 reset= 0
I.e. the whitepsace is required under XP.
Serg13
Do you still have any plans to add support for this to Advanced Installer?
It seems with Windows Installer 5 it became possible:
https://docs.microsoft.com/en-us/window ... ions-table
This is now possible for quite a while in Advanced Installer.
In order to implement it, please add a failure operation for your service.
For more information about this, please refer to our "Service Failure Actions Properties" article.
Return to “Feature Requests”
