Hi AI team,
I have an issue. When I have a "per maschine only" install type and a "for me only" install option enabled the uninstall process via my uninstall shortcuts are working fine.
But if I use the "Control Panel" -> "Add or Remove a program" uninstall button then the UCA prompt occures. If I type in the credentials the process afterwards will freeze.
How can I fix this?
Hendrik
