Hello everybody,
I am using AI 5.1.1 and my problem is the following:
Before the installation of my product begins, it is checked via the "Prerequisites" if Postgresql and a JRE are installed.
That works well so far, but if I want to install on a computer where several JREs are already installed, it lasts at min 20s until the first Dialog appears.
That's quite long and so I ask if there's an option for a small Pre-Installation Dialog, e.g. only with the text "Preparing to install" as it is realized in many applications (e.g. postgresql installer).
Best regards
max
