osherk
A problem to install framework 4.5 as a prerequisite
Any idea why I get the attached error when I run an installation with the following 3 prerequisites: framework 4.5, sql server 2008 r2 abd sql server 2012?
all of the prerequisites are under folder 'Feature-based' so I can have them all right before the installation without a specific wizard for the prerequisites.
freamework 4.5 error.png (20.46 KiB) Viewed 2405 times
Re: A problem to install framework 4.5 as a prerequisite
This is happening because the Net Framework and SQL prerequisites cannot be installed as feature-based prerequisites and you can see here why: So, the correct approach is to add them as Pre-Install prerequisites.
