adam@ibexuk.com
Prerequesits Dialogs don't display correctly
I'm using Advanced Installer 11.3
My install has prerequesit files
When windows installer (win 7 for instance) prompts to install the prequesite files it uses a differed font for the dialog UI (looks like Times New Roman) and also makes my "dialog_500x316.jpg" install image file look horrible (the edges of the logo in it become very distorted). Looking in Advanced Installer there doesn't appear to be any dialog options for the prequesite install so is there anything I can do about this to try and make these install dialogs look as good as . the same as the main application install dialogs that follow?
Many thanks
Adam
Irina
Re: Prerequesits Dialogs don't display correctly
I am afraid I need more information in order to make a correct test scenario.
A screenshot with the dialog would be very helpful.
Also, can you please send us the .AIP and .jpg file at support at advancedinstaller dot com so that we can investigate more?
Kind regards,
Irina
Ecaterina Irina Grosu - Advanced Installer Team
